what could be wrong with my trail boss
Old Nov 24, 2012 | 01:59 PM
yc456's Avatar
Default what could be wrong with my trail boss
Iwhat could be wrong with my trail boss
I have a 1990 trail boss 250 and it runs great but starting yesterday whenever I put it in reverse it just dies.... And shuts off but it goes into high low and neutral and runs perfectly its just that when I put it in reverse it shuts off why is this and how much would it cost to fix please share any information that you may have
Old Nov 24, 2012 | 02:04 PM
Polarat's Avatar
There might be a short in the reverse over ride. Try holding the button in before you put it in reverse and see it that helps.
Old Nov 24, 2012 | 02:09 PM
yc456's Avatar
I'm not sure what you mean? What button would I hold it sorry this is ny first ATV not to knowledgeable but it is hand shifter I don't know what button your talking about
Old Nov 24, 2012 | 02:17 PM
user493's Avatar
Moto Psycho
There should be a yellow button on the left handlebar.
Old Nov 24, 2012 | 02:19 PM
yc456's Avatar
The start button? The only buttons I've got are are the red on and of slider the gray start button and the gray lights button and then the right handle bar has the gas
Old Nov 24, 2012 | 05:53 PM
Just pull the tank cover and left side cover and at the top of the circuit board trace the black wire to the reverse limiter module. Just unplug this wire from the circuit board and tuck under the headlight pod out of the way. You've eliminated this shorted out module (common problem) and will now have full power in reverse without having to push the over ride button. OR you can spend about 60-70 bucks for a new module which almost no one does.This was just a reverse safety device that always ends up failing. OPT
nachop
Feb 14, 2018 06:57 PM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
ghost civic
Jul 19, 2015 10:13 AM
Gnuters
Jul 19, 2015 10:03 AM
