2000 ds650 torque specs
Old Nov 27, 2012 | 08:58 AM
Polaristrailboss350's Avatar
Default 2000 ds650 torque specs
I am doing a top end rebuild on my 2000 ds650 and wonder if anyone knows the torque settings for when I go to put it all back together. I went onto can am website to see if they had a service manual but all they had was a owners manual. Does anyone know where I can get a free one online? If someone can tell me the torque settings and maybe a place to get a service manual that would be great
Cheers
Old Nov 30, 2012 | 11:32 PM
300ridin's Avatar
Cam and Valve Cover bolts are 89lbf-IN--- 2 on the Jug are also 89 lbf-in and the longer bolt on the head is 24 lbf-FT and the nut is 44 lbf-FT ..... this info is from a 2003 baja so i would assume its the same.
Old Dec 8, 2012 | 02:32 PM
thanks i think it would be the same as well. can anyone confirm this before i torque it down?
Old Dec 12, 2012 | 05:59 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
The long head bolts 20 Ft Lbs
The nuts 39 ft Lbs
The nuts should only be used 2 times.
If this is the first time head is apart, you can use them 1 more time.
Apply light oil to threads before assembly.
After 5 hours of running - re-torque.
dannytas
Sep 26, 2017 06:31 PM
Gwolf228
Feb 18, 2017 01:36 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
