110 chinese atv no fire
Old Dec 8, 2012 | 03:08 PM
DannyBoat's Avatar
Default 110 chinese atv no fire
i have a chinese atv that wont fire, i have .019 kilo ohms on kill switch pin
with all switches on
ac power pin i have 414 ohms
timing trigger pin .144 ohms
42 volts on ignition power pin while cranking
0.1 volt on timing trigger while cranking
cdi pin to ground .4 ohms
ignition coil to ground while cranking is 0 volts
what can be the problem
Old Dec 8, 2012 | 08:34 PM
LynnEdwards's Avatar
Electrical Expert
My comments in blue:
Originally Posted by DannyBoat
i have a chinese atv that wont fire, i have .019 kilo ohms on kill switch pin [This is wrong. 0.019 Kilo Ohms is 19 ohms. That will kill the spark dead. Please recheck that reading again. For you to get spark this wire needs to be open (infinite ohms)]
ac power pin i have 414 ohms [Good]
timing trigger pin .144 ohms [Good]
42 volts on ignition power pin while cranking [Good]
0.1 volt on timing trigger while cranking [Low, but maybe OK. Does the reading reliably read 0.1 volts, and does this reading reliably go to 0.0 volts when the starter isn't being cranked?]
cdi pin to ground .4 ohms [I'm not understanding this... What CDI pin to ground?]
ignition coil to ground while cranking is 0 volts [If your kill switch pin really is grounded hrough 19 ohms then this reading is what I would expect.]
ultangler
Nov 30, 2024 01:35 AM
fredrikrosen
Oct 29, 2016 07:56 PM
mrtidy
Feb 3, 2016 05:00 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
IMLN
Sep 28, 2015 03:32 PM
