Neutral bulb replacement on Xpedition.
I did a search and came up with it some N & R indicator bulbs can be replaced while others cant. Seemed to vary by machine and yr..
I'm pretty sure its just the bulb and not a switch I saw mentioned, with the N wire hooked to the R indicator it lit up, but the N wouldn't light up with the R lead hooked to it.
So is it possible to change the bulb on my 01 Xpedition? Is it possible to just switch the N and R plates? Thanks.
The N/R bulb assy (4040054) just pops out of the housing.This is used in a lot of different Polaris atvs. About 12 bucks at Cycle Parts Warehouse,but check a local dealer. Here's an example. http://www.ebay.com/itm/OEM-Polaris-...item25769118b0
OPT
OPT
