Tire weight question.
Old Jan 1, 2013 | 02:32 PM
WilliamBos's Avatar
Default Tire weight question.
Below are my stock 489 weights and tires that I want to run. I would like to run 26" just wondering if the extra weight will affect me much. Tire weights came from manufacturers sites.
Carlisle AT489
25x8x12 14.1 lbs
25x10x12 18.7 lbs
Reptile Radials
25x8x12 22 lbs
25x10x12 27 lbs
26x9x12 26 lbs
26x11x12 30 lb
Old Jan 2, 2013 | 07:25 AM
TLC's Avatar
TLC
My friend notice a performance lost moving up to 26" on his 660 Grizzly.
With a 450 your would notice it even more. The option I like is to split the differance,stay with stock 25" sized tire but buy a tire with a more aggressive thread for improved traction.
Old Jan 2, 2013 | 01:47 PM
papahouse's Avatar
I run the 26" Reptiles on my '04 Honda Rancher AT for the past 2 years with no problems.
Old Jan 2, 2013 | 01:48 PM
papahouse's Avatar
BTW I also run 27" XTRs on my 500 Vinson with no issues
Old Jan 2, 2013 | 02:13 PM
Maniac01's Avatar
Do you ride at high speeds? If you do, you will notice some power robbing. Nothing major, but noticable. You could try it and do clutch work if your power isn't up to par.
Old Jan 2, 2013 | 04:03 PM
WilliamBos's Avatar
Thanks Guys. Max road speed here is 30mph. I will try the 26", and if I lose a bit, Dalton has a clutch kit that will work nicely.
Old Jan 3, 2013 | 06:26 AM
TLC's Avatar
TLC
For general trail riding at you will be fine, even if you get into the nasty stuff your Low Range does not care how heavy the tires are.
Low Range will pop a axle or CV joint before it runs out of wheel turning power.
Old Jan 3, 2013 | 09:21 PM
SOLOLUCKY's Avatar
i went to 26" mud lites on my 2001 500ho...no power difference was noticed and it werks better in the mud than the stock goodyear rawhides.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
bigred20653
Oct 2, 2015 10:05 AM
Bigtwin700
Sep 9, 2015 09:32 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
