2007 hawkeye
Old Jan 3, 2013 | 09:40 PM
cncman's Avatar
Default 2007 hawkeye
My son's 2007 Hawkeye starts, idles, and runs fine but at full throttle the engine revs high,then almost dies,revs high, almost dies, etc. New fuel filter and vent tubes are clear. New plug and boot. Any ideas?
Old Jan 3, 2013 | 09:51 PM
Check that you have good fuel flow to the carb. Just pull the fuel line. If you haven't checked the carb out,could be needle and seat problem not allowing enough fuel,water in the fuel,etc. The carb is not the easiest to get to,but sounds like this might be the problem if fuel flow is good. Plus check that the tank vent is clear. On the fuel flow crank the engine over and see if you have good flow through the line,if not could also be a fuel pump problem.Does sound like fuel starvation or tank vent tube kinked causing a vapor lock condition?? OPT
Old Jan 7, 2013 | 06:41 AM
cncman's Avatar
Default 2007 hawkeye update
Thanks to old polaris tech for the info. The problem was trash in the fuel valve under the tank. It was allowing enough fuel to run normally but not under load. Cleaned valve and tank and it is running fine.
Old Jan 19, 2013 | 10:04 PM
Nikko Spiotto's Avatar
heres a picture of my quad and it has super swampers 27/12.5/12
and im looking for a clutch kit and a lift kit and ideas i was going to make my own lift kit for it
Old Jan 20, 2013 | 08:14 AM
Check with EPI,High Lifter,etc as to anything that they may have. Hawkeye is made by Eton or Aeon and it's clutch system is different than other Polaris models.Not too may after market items last time I checked. There are different weight rollers offered,but don't know if this would help. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
Old Jan 22, 2013 | 11:24 AM
ya i been looking and what happens if i put a different clutch on it ? would that do anthing and i still cant find a lift kit
Old Jan 22, 2013 | 11:49 AM
Problem is that it wont take a regular type Polaris clutching system that I'm aware of. Any clutch kits would have to use the roller designed type clutch system that it already has. This is really an entry level quad and not too many (if any) after market performance items are available for it. OPT
Old Jan 25, 2013 | 07:24 PM
ok thanks for your help and i have another problem im running 27/12/12 vampires super swampers and i broke two front axles pulling out a utv lol and i pulled it out but i broke my front axles so where can i get some good quality ones
Old Jan 25, 2013 | 07:43 PM
Cheapest place I've found so far,unless you want to try to rebuild each cv joint.
2006-2007 POLARIS HAWKEYE 300 4X4 Front Complete Axle
They're $260 each at Cycle Parts Warehouse. OPT
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
snowolson
Aug 31, 2015 03:51 PM
