what Type of Ignition switch
Old Jan 5, 2013 | 02:58 PM
bolt500's Avatar
Cool what Type of Ignition switch
I want to start by thanking you for helping us out with your knowledge. I have a 2000 scrambler 500 4x4 a project atv, I bought the atv in trade and it needs work and i do have a clear title with it. Some one cut the ignition switch off including the plug. My question is what type of switch do I need ? Do I need a three position with {off-on-start} if so does it take a six pin connector or not my wires that are cut are color coded as two red red,two black black, two brown brown, and two red black with strips. I was told that if i didnt get the right switch the atv would not get spark or start. I would like to order the right switch and a part number would be great. And is there any place i can get a plug for this switch.
Old Jan 5, 2013 | 06:04 PM
Only way to get a new connector for an OEM switch is from a new harness or try to find a used one from Ebay. Have had this happen plenty of times when machines were brought in that were stolen or vandalized. As far as the ignition wires one red/black goes to red to turn ignition on and one red/black to the other to engage the starter.Plus cant rember on the black wires? You would have to have some kind of momentary/intermittent toggle switch(or some kind of three way toggle like you mentioned) for this to work and may have to use the emergency kill as a primary ignition kill?. Have had people rig wiring up this way,but in the shop we couldn't do this. Had to do it the right way! Oem ignition switch was # 4110264 but was replaced with #4012163. About $45 new. You can use either switch if you find a cheaper one on Ebay. Any 2000 model harness would work just to get the switch connector. It's a shame that Polaris doesn't sell these connectors separately without having to do this and I don't know who supplies them. OPT
Old Mar 10, 2013 | 02:04 PM
bolt500's Avatar
Smile up date information
I would i to say thanks to old polaris tech for the advise I bought a complete wiring harness on e-bay for $36.00 with the switch and it worked out nice.
Old Mar 10, 2013 | 02:11 PM
A lot better than paying about $300 for a new one that I've found online
skinnyr6
Aug 25, 2023 02:18 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
WILLLANE8302
Aug 7, 2015 08:24 AM
