Gas Tank Compatability
Old Jan 12, 2013 | 06:16 PM
Silencer1's Avatar
Default Gas Tank Compatibility
I have a 2002 scrambler 500 that's missing the gas tank. Will a 98-02 scrambler 400 gas tank work?
Old Jan 12, 2013 | 06:57 PM
Your fuel valve on the 2002 500 is tank mounted versus the remote fuel valve with two tank fuel line adapters on the 98-2000 model 400 tanks. Plus tank mounting is different(can be adapted) You would have to have the remote fuel valve also from the 400 2 stroke tank and adapt it to work with the 500 fuel pump.The fuel pump on the 500 and different type carbs on both machines are the main reason for the tank differences.Gravity feed on the two strokes versus a vacuum fuel pump on the 500 carbs. You can look here at the different model tanks and their differences. Browse
OPT
Old Jan 12, 2013 | 07:42 PM
Silencer1's Avatar
Alright, thank you. Do you know of any other gas tanks that will mount or does it have to be a 500 scrambler? I need to buy a tank and don't really want to buy a new one.
Old Jan 12, 2013 | 08:08 PM
Scrambler tanks are a little slimmer than Sportsman tanks and are specific to this model. You can keep a check on Ebay and Craigslist as far as used tanks go or a new one is $119 here.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
Old Jan 12, 2013 | 08:35 PM
Silencer1's Avatar
I'll keep checking around. Thanks again.
Old Jan 12, 2013 | 08:41 PM
There is also a listing here for $108 and shows that it is also used on Trailblazer 250s also and several different year models of the Scrambler 500. You could check for a used one to from any of these models,but be careful on used tanks. Or just bite the bullet and get a new one! 2520241 ASM.-FUEL TANK W/ VALVE $108.09
OPT
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Jason Campbell
Sep 7, 2015 02:25 PM
