Kawasaki Bayou 300-What is this??
Old Jan 15, 2013 | 10:04 AM
sixpack_sid's Avatar
Default Kawasaki Bayou 300-What is this??
I just bought a Kawasaki Bayou 300 4 wheeler. It's missing some parts and I would like some help to figure out if I need those missing parts or not. Ha ha.
There is a broken white round piece on the handle bars that has a cable going down to the tranny. I'm assuming this is a safety switch?? Can anyone help?
Also when I hit the shifting lever with my foot, the cable doesn't move. Is this related to the broken piece on the handle bars?
Thanks for the help!
Old Jan 22, 2013 | 07:38 PM
Cummins Driver's Avatar
It sounds to me like you are describing the reverse cable setup. There is supposed to be a twist **** on the white piece you are seeing I believe. That pulls the cable which pulls a lever on the transmission. When that lever is pulled, it can be kicked down from neutral into reverse.
Old Jan 22, 2013 | 08:20 PM
Thanks for the reply! From what you are describing, it makes me wonder if the switch is in the reverse position since I can only shift up one gear or down one gear. It doesn't seem to click in when I go through the gears. Could that be why?
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
