polaris 325 magnum
Old Jan 17, 2013 | 02:40 AM
buddyhester's Avatar
Default polaris 325 magnum
my polaris 325 magnum rear end slipping want go
Old Jan 17, 2013 | 02:50 AM
The Magnums were bad after a few years on the rear prop shaft coupler splines stripping out at the rear differential. Grease zerks were hard to grease because because of the box frame,plus a lot of people over looked them. http://www.cyclepartswarehouse.com/f...2000&fveh=5502
item #17. About $30 for the part ,but if it's the problem the rear axle housing and rear differential have to be removed to replace it. Just jack up the rear end,place in gear and turn the tires. You should feel the coupler slipping if it's bad.
OPT
Old Jan 17, 2013 | 02:55 AM
it is belt driven dont have a chain
Old Jan 17, 2013 | 03:07 AM
Look at my post above,I realized that it was a Magnum,not a Trail Boss and amended it. I shouldn't be answering questions at 3 am. Going back to bed OPT
Ramman1
Aug 11, 2022 01:53 PM
ronnierhino06
Nov 9, 2015 12:56 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
jettman
Jul 6, 2015 12:16 PM
