polaris 325 magnum
The Magnums were bad after a few years on the rear prop shaft coupler splines stripping out at the rear differential. Grease zerks were hard to grease because because of the box frame,plus a lot of people over looked them. http://www.cyclepartswarehouse.com/f...2000&fveh=5502
item #17. About $30 for the part ,but if it's the problem the rear axle housing and rear differential have to be removed to replace it. Just jack up the rear end,place in gear and turn the tires. You should feel the coupler slipping if it's bad.
OPT
OPT
01, 325, atv, date, differential, grease, housing, mag, magnum, pb, polaris, production, rear, replacement, years
OPT
