Light Modification Not Working
Old Jan 18, 2013 | 03:10 PM
Daverdawg's Avatar
Default Light Modification Not Working
Ok i did the headlight modification (low beam and high beam to come on at the same time) using the relay instead of thew diode and it didnt change anything the lights still operate the same. I triple checked everything and i cant figure out whats wrong. I used the directions and schematic from a couple of posters in here. Yellow wire spliced to the 86 terminal, brown wire spliced to the 85 terminal, red with white stripe to the 87 terminal, and green to the 30 terminal. All these wires being the ones going to the indicators inside the pod just under the headlight (yellow/high beam) (brown/neutral reverse) (red/middle) (green/neutral reverse. Should i have spliced the 85 terminal to the brown wire going the lighter/auxilary instead of the brown wire going to the neutal/reverse indicator? and the 87 termimal to the red power wire going to the lighter/auxilary also? i did see another post where that was the way to do it but i figured the red going to the auxilary mite be too much power for the switch to handle. I am electrically challenged as you can see so any help here would be much appreciated!!!
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
