2006 outlaw won't idle
Old Feb 27, 2013 | 11:52 AM
lentalmadge's Avatar
Default 2006 outlaw won't idle
I tried that also. It still will not idle at all, shuts right off!
Old Feb 27, 2013 | 11:57 AM
TLC's Avatar
TLC
You just have reply under your post,not make a new one each time. Take the throttle cap off and my sure those contacts are not touching by eye.
Old Feb 27, 2013 | 12:01 PM
They are not touching at all, about 1/8" apart1
Old Feb 27, 2013 | 03:52 PM
You don't have to make 3 separate posts on the same subject! Just go to the bottom of this page and hit post reply! Simple things first on the atv. Since you say the throttle is adjusted about to 1/8" slack at the thumb throttle and all you did was to clean the pilot jet,are you sure the jets are tight,did you make sure the slide needle is properly in place,plus have you simply tried to adjust the idle with the adjuster? http://www.cyclepartswarehouse.com/f...2006&fveh=7115 Item # 16. If none of this helps,it sounds like something somewhere in the carb isn't right after you put it back together,since you said it idled good before?.
Old Feb 28, 2013 | 08:42 AM
I am new to this site so thanx for the etiquette lesson! I've already tried everything you suggested to no avail. I guess I'll have to pull the carb back off and start over again. something tells me it's the floats. Or maybe I put the jets in the wrong spot. In other words, human error! Thanx for your help and I'll let you know what I find!
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
snowolson
Aug 31, 2015 03:51 PM
