brakes
Old Mar 2, 2013 | 08:24 PM
steelclark's Avatar
Default brakes
i have a 94 kawasaki bayou. im having problems with replacing the rear brake shoes. the problem im having is installing the drum back on with the new shoes.
Old Mar 2, 2013 | 09:15 PM
Ms8091's Avatar
There should be an adjuster to move the shoes inward so it can slip on. If not, you may have a shoe out of place a little bit.
Old Apr 29, 2013 | 09:59 AM
mbriggs's Avatar
I'm having that same trouble with my son LT80. Brakes are aligned well. Drum wont's slip over the new pads. I can get it on with alot of work however the wheels won't spin.
Any Help?
Old Apr 29, 2013 | 10:00 AM
mbriggs's Avatar
Ms8091,
did you ever get a solution to this? I'm having the same trouble.
Old Apr 29, 2013 | 10:02 AM
mbriggs's Avatar
oops...
Steelclark,
Old Apr 29, 2013 | 10:14 AM
TLC's Avatar
TLC
There are two butterfly nuts outside the drum brake housing that close the shoes in.
One is for the hand brake and one is for the foot brake.
Here is a pic of the two butterfly nuts .its a 2012 Honda 500 Foreman but there all mostly the same. (Can,t believe the newest 500 Foreman still uses drums)
Old Apr 29, 2013 | 11:20 AM
mbriggs's Avatar
Yes, i have that so the shoes are all the way down..."zero'd out" if you will.
Drum still wont' fit over.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
