Why we ride Can-Am!
Thought you can-am guys would like this vid I found on the tube
this a great vid to throw at all those visco haters
@ 4:25 gave me chills when he cleaned out the pipe
I like Visco or the polaris system. Its the only two setups that give you "true 4wd" while on the fly ,without having to stop to engage diff lock then stop again to disengage it once more to put it back in 2wd or 3wd so it can be steered again.
I agree with you. polaris & can-am have the best front diffs out there.
Not much mud around here in southern Arizona. We have a couple old Honda 2wd and an old Yamaha 4wd for putting around the desert roads and trails.
Having said that, I am impressed as hell. Just put up a CanAm logo at the end and run it as a commercial.
I see the PVC air intakes in front of the riders. Are there traps on the exhaust to prevent intrusion if an engine dies?
Matt B
Matt B
Matt B
Matt B
as long as the engine stays running, theres enough back pressure to keep the h2o out of the pipe. if the engine stalls while the pipe is under water, usually you can just stand the atv up to drain the pipe, and then remove the plug on the bottom of the baffler- plug the exhaust , start it up and force it out the plug hole (the lowest point of the baffle can) can-am puts their air cleaner way up under near the bars- (where most atv's have gas tanks) can-am put the outty's tank down low in the rear of the frame to help with keeping a low center of gravity. there's also a cvt breather located just under the dash pod- sometimes you'll see 3 snorkel tubes- one for the air intake, one for the cvt intake and one for the cvt exhaust - these things are designed to be ridden in water upto the seat
Thanks for the explanation.
We just got here in September. We spent most of our vacations here, so it made sense to relocate. The dirt roads start literally at the end of our driveway. We have friends of friends who have ridden their ATVs from Mesa to New Mexico - all off-road.
We are old farts and new to ATVs so we have utility ATVs. Twenty MPH still seems REAL fast. Actually leaving the ground seems too scary!
Matt B
Matt B
Matt- I just returned this morning from Tempe az. - wish I had more time to spend there - was there on business- such a nice town, so clean. it felt strange not being surrounded by forest! you're right tho- there no place around there to ride these types of atv's. i'd own a sporty out there for sure.
They have some serious talent and serious machines.
