2007 Honda Foreman Line Off of Bottom of Carb
I came back from a ride and noticed fuel leaving a trail behind me. I noticed a line coming off the bottom of the carb was the problem. I have not been able to locate where it goes to. Any thoughts?
that line doesnt go anywhere. it serves 2 purposes, drain and overflow. next to it is a flat head screw that goes into the carb bowl. loosen it and the fuel should drain out the line. usually thats not the problem but u can loosen and tighten it a couple times to make sure its seated good.
inside the carb is a little pipe with a hole in the top which is usually above the fuel line, if your float isnt shutting off your fuel correctly then it overflows thru this pipe and out the hose. this is probably ur problem. carb may need a good cleaning or ur fuel needle that shuts off the flow is worn. sometimes u can shake the 4wheeler real good and if theres a lil bit of crud keeping it from closing then it will dislodge and stop overflowing
