300ex clutch problem
Old Mar 22, 2013 | 08:30 PM
tjjd12's Avatar
Default 300ex clutch problem
I have a 98 300ex that I purchased in December. When I pull the clutch in in first gear, it sort of jerks and then disengage. The other thing is when I put it in reverse it just goes, even with the clutch pulled all the way in. Any ideas?
Old Mar 22, 2013 | 09:03 PM
lugene's Avatar
my blaster had the same problem ,it would be probably that the plates are "stuck" atttach on each other, that's a bad quality clutch kit, change the clutch kit for a better quality (plates, springs).
Old Mar 22, 2013 | 09:14 PM
tjjd12's Avatar
Oh boy. Alright thank you
Old Mar 23, 2013 | 09:48 PM
Scooter86's Avatar
Knows Old ATV Questions!
The first thing I would check is for looseness in your clutch cable. Also make sure the cable isn't getting hung up anywhere and is not frayed. If that checks out and you do open up the clutch, be sure to inspect the basket for grooving which can also cause your clutch to stick. It isn't super hard to change out clutch plates.
Old Mar 24, 2013 | 10:37 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Also IMO could be wrong oil in engine.....The incorrect oil could cause clutchs to stick together...Need oil for an wet atv clutch....
Old Mar 25, 2013 | 12:40 AM
sprinklz's Avatar
doesnt the wrong oil make it slip instead of stick?
Old Mar 25, 2013 | 02:30 PM
budedm's Avatar
Sounds like the basket is grooved. Simple fix. File all the ears smooth.
Old Mar 25, 2013 | 07:23 PM
Loved
Community Favorite
Yes both...slips because of moly in oil which is slick..slick mean sticks some times also if atv sit for an periods of time
Old Mar 25, 2013 | 07:25 PM
Loved
Community Favorite
Make clutch disc stick together sometime when an atv sets.
skinnyr6
Aug 25, 2023 02:18 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
honda71
Jul 8, 2015 02:13 AM
