Adjusting "toe-in", self or dealer?
Old Mar 25, 2001 | 09:17 AM
tealboy's Avatar
I think I have a "toe-in" problem and need to adjust. In order to go straight, the handlebars need to be pointed slightly to the right. The tires are inflated equally so i know it is not that.
I read the manual on toe in and I am not sure how easy of an adjustment it is. Just wondering if my problem sounds like a toe in problem and if I should take it to the dealer or have you made such adjustments yourself.
by the way, it is a trx300 4x4 but I also need to adjust the kaw 300 bayou
Old Mar 25, 2001 | 12:23 PM
TEXMud's Avatar
If its a 4x4 you should have a toe-out problem. Do it yourself. Here are some good instructions on how to do it.
Old Mar 26, 2001 | 08:58 AM
rockhopper's Avatar
You can do it yourself with the instructions pointed out by TEXMud ........ I have done mine and rechecked it several times to make sure it is still where I set it. Bouncing off logs and rocks and such, tends to throw things out occassionally.
Old Oct 13, 2002 | 06:11 PM
Hercules's Avatar
Default Adjusting
I don't use toe out on my Honda Foreman ES. I use it mainly for hunting/slow moving, and a 1/2 inch toe IN makes a big difference in easiness of handling compared to toe out. Your handlebars are a lot harder to turn with a toe-out. The 4x4 becomes a little more stable at high speeds too with toe-in.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
snowolson
Aug 31, 2015 03:51 PM
