Pro Design Cool Heads???????
Old Mar 25, 2001 | 12:05 PM
Sanddude's Avatar
I was lookin into buying one for my LT but wasn't sure if they would be a good investment. Any help would be appriciated.
Old Mar 25, 2001 | 01:07 PM
H300F's Avatar
well since your stock head is already milled... keep it and dont get a cool head. unless you are always tearing the head of, then the cool head would be good since it has oring gaskets and they are reusable. and the only other thing you will get over your stock milled head is cooling and the choice of domes if you want to change them for different conditions.
if i were you, keep the milled head you have.
Old Mar 26, 2001 | 12:59 AM
cdracing's Avatar
Get one A buddy of mine added one on his Banshee it was like night and Day. I can get you one go to
colbykostman.tripod.com
Old Mar 26, 2001 | 11:20 AM
cdracing's Avatar
Let me explain. I understand that alot of people beleive milling your head is the answer but in effect it is not the best way to go. when you have the head milled it will increase the compression of your motor but it also changes the squich area in your head and alters the proper cumbustion in your cylinder( this is bad and will not do the motor any good over time). For the max performance and life for your motor a cool head is the best way to go, it raise the compression and hs the proper squish area.
Just thought I would expand on the first post from cdracing it was from my brother in law he works for me and didn't explain the diff thanks
Old Mar 26, 2001 | 11:38 AM
Dill's Avatar
I disagree. A good builder can take your stock head, mill and rechamber it, and set it up to use O rings. MP Racing and LRD are such builders.
fordfaithful21
Dec 7, 2015 05:52 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
lancemll88
Sep 5, 2015 03:16 AM
quickwhips
Sep 2, 2015 06:53 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
