Clutch/belt engagement problem:
Old Mar 25, 2001 | 06:19 PM
Xplor's Avatar
Actually this is for my sled which is basically the same system as my ATV's. Yesterday I rode all day as usual but towards the end of the ride I went once again in some really deep, heavy snow and the sled would not advance. I thought I had smoked the belt so I changed it. No good. Upon load the belt will not engage on the front pulley. It smokes it.
I removed the belt once again and revved it without. I noticed the front pulley "hits" all at once. In other words it does not gradually get smaller but pops in at once...
Any ideas what this could be? I am clueless.
Brian
Old Mar 25, 2001 | 08:18 PM
KevinDevitt's Avatar
Thats strange....
Broke spring or broke or gauled wieghts.
No other thoughts than that....
KD
Old Mar 25, 2001 | 09:05 PM
SHAGGY500HO's Avatar
XPLOR
I assume that the track and secondary clutch turn freely?
Old Mar 25, 2001 | 09:39 PM
thenewfiebullet's Avatar
It has to be the spring broken. The spring keeps the movable sheave from coming in and the weights are what pushes it in. Is the sheave moving at low revs? If so, the spring is no longer providing any resistence, so it will move in all the way at once.
Old Mar 25, 2001 | 10:22 PM
Xplor's Avatar
****- The track and secondary are turning. I thought I was learning something yesterday and undid the secondary...all was fine.
NewfieBullet- I can hear the sheave pop in at low RPM's upon take-off. The whole belt/clutch system sounds off...very noisy and sounds like my belt is engaging then slipping too. Must be the spring because with the belt out it just goes "snap" and goes in all the way at once. But then again with the belt on it didn't seem to squeeze enough to grab the belt...thus smoking it?!
Can I do this myself? Should I take it to the dealer and just have it all checked at once? Shouldn't be more than 1hr work for them...plus they can check alignment too.
Old Mar 25, 2001 | 11:37 PM
bdscram1's Avatar
its not smart to start with out the belt on. sounds like your primary spring is broke. it uses the spring for pressure to keep the belt from slipping. do it yourself its easy and save some money. I have to ask. this is a polaris isnt it?
later
bdscram1
Old Mar 26, 2001 | 12:52 AM
Xplor's Avatar
Nope...Ski-Doo.
Old Mar 26, 2001 | 09:31 AM
Zorro's Avatar
I had told you not to buy a skidoo!!!
lucky for bomb that their sleds are the coolest looking.
Old Mar 26, 2001 | 10:05 AM
I'm alot more familiar with Arctic Cat clutchs, but I think it should be pretty straight forward with the Bombi too. Do it yourself.
The reason the belt is smoking is because it's grabing TOO much. If the spring is broke and the moveable sheave is shifting up all the way right off idle, then the reason the belt is smoking is because it's in too high a "gear" to move the sled.
If you had a Cat you'd be able to inspect the clutch without taking anything apart, but with Ski-doo you have to remove the cover. You shouldn't have to take of the clutch though, so unless there's something with Ski-doo I don't know about, you shouldn't need any special tools.
flyin-lowe
Dec 1, 2017 03:18 AM
franklyme
Oct 21, 2016 07:18 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
