1995 scrambler 400
Old Apr 30, 2013 | 05:17 PM
sharpshooter97's Avatar
Default 1995 scrambler 400
I picked up a 1995 scrambler 400 that had the crank go out and broke the case. How many different year 400's will fit in this quad?
Does anyone have a old 400 2 stroke laying around they want to sell. Quad is in pretty good shape. Well worth fixing.
Jeff
Old Apr 30, 2013 | 05:27 PM
1994 to 2003 last year model.
Old Apr 30, 2013 | 07:44 PM
Are you saying that all the parts will interchange with each other? 95' case with a 98 cylinder... ect? or are the internal workings particular to each year. My buddy has a 98 jug. I can get a used case half. or will that not work.
Jeff
Old Apr 30, 2013 | 08:13 PM
Major changes were electrical components over the years(stators and flywheels and early model recoil starters). All internal mechanical parts will interchange. As far as engines goes even the 350 is the same. Only engine difference is the cylinder itself and the bore. Bore was 80 mm versus 83 mm on the 400. Stroke was the same on both engines.Never tried it,but both cases should even interchange. So you actually have a choice between a 1990-1993 350 or a 1994 - 2003 400 engine cases.
Old Apr 30, 2013 | 09:02 PM
mrtwostroke's Avatar
not all pieces between 350 and 400 interchange. The I believe the ride side cover that has the water pump in it is different. But only because the recoil is different.
Old Apr 30, 2013 | 09:12 PM
Just the recoil and flywheel are different on the early models with the two piece recoil cover.Cases,internals should still be the same. http://www.cyclepartswarehouse.com/f...1990&fveh=5342
exmotocrosser
Sep 13, 2019 06:12 AM
wendal
Oct 31, 2017 03:31 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
