new clutch lever on 400ex
Old Mar 25, 2001 | 10:20 PM
MiStA400EX's Avatar
i was just wondering what you do with the electrical wire that is attached to the clutch mechinism when you put on a new clutch lever and perch? also what is a good clutch lever and perch? i was just going to get the pep easy pull clutch and perch, but i dont know if there is somthing that is cheaper or works better? any suggestions? thanks,
Chris
2001 400ex
14 tooth front sprocket
AC Pro peg nerfs
Renthal 400ex bend bars
Old Mar 26, 2001 | 12:00 AM
ROCKET400EX's Avatar
From what i remember, there is 2 wires you can connect when you take off the stock lever, then you can bypass the auto cut off if its in gear, but then, you will be able to turn it over, even when its in gear. I heard the CR250 levers are good, but then they also have the PEP EX clutch lever that you can get from Nac's Racing.
Old Mar 26, 2001 | 08:54 AM
MiStA400EX's Avatar
thanks for the help rocket,
Chris
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
cdstang
Aug 31, 2015 07:52 AM
