Scrambler 400 throttle response
Old May 5, 2013 | 06:07 PM
Connor Schuster's Avatar
Default Scrambler 400 throttle response
Ok so I got my 2001 polaris scrambler 400 from the shop last week. It has a fresh topend bored .020 over and when I mash the throttle it takes of real slow and the throttle response is also really slow it almost feels as of there isn't any bottom end. Thanks for you in outs guys
Old May 5, 2013 | 08:18 PM
First thing I could think of if you've eliminated any carb or fuel problem since you have a new top end is either a worn belt or rear clutch ramp button wear. Either one or both could affect acceleration,power or top end speed.
Old May 5, 2013 | 08:21 PM
I kinda figured a belt it has good top end speed it just takes a long time to get up there ill check my belt tomorrow how could I check the clutch ramp
Old May 5, 2013 | 08:33 PM
Place a straight edge over both clutches and pull the top part of the belt down. If the distance between the top of the belt and straight edge is 1 1/2 " or more,then time for a new belt. You really need to tear the rear clutch down to see if the buttons are worn,but you can remove the belt,hold the rear sheath of the clutch and turn the outer part. If you hear any metallic noise or feel a grinding,then it's pretty certain you need to look into the rear clutch. Plus don't over look the 6 glide buttons in the front clutch also. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old May 5, 2013 | 08:37 PM
Awesome thanks alot
Old May 6, 2013 | 04:20 PM
I checked the belt I believe that it is the belt is there a truck to taking it off and outing in a new one
Old May 6, 2013 | 05:14 PM
Just pull up the center of the belt and walk it off the rear clutch. Install the new belt with the numbers facing you on the front clutch first and walk the belt over the rear clutch. Plenty of videos on YouTube on different repairs for Polaris atvs.
scram5050
Aug 30, 2024 01:39 PM
COFatboy
May 2, 2020 12:06 AM
Knackknack
Aug 19, 2015 07:45 AM
scram5050
Aug 19, 2015 02:19 AM
maxjung
Jul 13, 2015 05:11 PM
