2003 polaris 90 sportsman no spark
Old May 7, 2013 | 07:02 AM
bigbumprider's Avatar
Default 2003 polaris 90 sportsman no spark
I am trying to figure out why my kids 90 has no spark, any info will help..
It cranks over but no spark, I tested the top of the ignition coil the 2 post and got a reading of .8 ohm and when I tested the spark plug boot to the top of the coil, my meter was reading OL, does this mean my spark plug boot to the coil is bad? What would I check next? What reading should I get by ohm the coil?
Old May 7, 2013 | 07:27 AM
Pull the black wire from the cdi and see if you have spark. If no spark,then check the wires from the stator lading to the cdi. BLACK to White/Red 450 ohms,Black to Black/Red 800 ohms.
Coil tab to ground .2 to .3 ohms. Coil secondary: wire to coil tab 3000 to 4200 ohms(cap removed) plug cap around 5000 ohms. All measurements + or - 20%. Plus here's a link to a 2001 90 manual that would be the same on wiring specs. http://gh-ftp.com/ORV%20Manuals/Pola...96%20-%202001/
3quadbob
Sep 18, 2016 09:46 PM
Thanos
Jul 12, 2015 08:40 PM
yellowpolaris
Jun 21, 2015 11:13 AM
atv1972
Jun 18, 2015 09:31 PM
CanadianViking
Feb 16, 2001 11:56 AM
