08 500HO high beam wires?
Old May 12, 2013 | 08:40 AM
tux's Avatar
tux
Question 08 500HO high beam wires?
My high beam was not working on my 08 SP 500HO,when i turned the bulb to take the light out the bulb/harness & wires came with it.So now I have the bulb with only about 4" of wire one yellow one brown.The ends of the two wires only have about 1/16th to 1/32nd of bear wire so i am thinking that the original connection was not good.I tested the bulb and it is good so my problem must have been this poor connection.My problem is that I can't see where the yellow & brown connect.There is a main haeness behind the head lite that comes from the kill switch & hi/low switch so i'm thinking it must connect in this harness but where.Does anyone know where they connect to? Thanks Tux.
Old May 12, 2013 | 09:00 AM
You may need to remove the headlight lens to get into this harness area to find the Yellow and Brown wires. This is where all the twisting and turning happens and wires can get cut and damaged. I've had this happen several times. Just splice the wiring and use a little sheathing if needed to protect from future damage.
Old May 12, 2013 | 12:11 PM
tux's Avatar
tux
Thumbs up 08 hi beam wires.
Thanks Polaris Tech I will get into the harness today. The connection has got to be close to the head light as i only have 4" of wire.As for your main job when I retierd I sold my alarm clock and put the money towards a real good one for my wife problem solved. Thanks Tux.
Old May 12, 2013 | 04:21 PM
tux's Avatar
tux
Smile 08 head light wires.
polaris Tech: Again thanks for the info. Took the head light lens off was able to get at the harness splice in some extra wire and problem solved. Thank's tux.
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
ltrmc02
Jul 22, 2015 04:50 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
Chocobamofo
Jul 10, 2015 07:46 PM
