fuel pump issues ?
Old May 13, 2013 | 12:19 PM
chuck1177's Avatar
Default fuel pump issues ?
i believe my fuel pump is going out but im not for sure! my pressure is down to 20 psi and im only getting 6.9 volts to the pump , is the 6.9 volts suffiecent enough to run the pump or what ? that voltage reading is with just the key on
Old May 13, 2013 | 12:43 PM
Manual says that at the pump the electrical connector should show between 7 to 14 volts. If the voltage shows less than 7 clean the connector,plug back in and turn key off and on a couple times to see if pump then primes up. If it doesn't, check that the battery is not the problem first by having it load tested.If battery is eliminated as a problem or replaced and it still shows less than 39psi,the pump needs to be replaced.
Old May 13, 2013 | 12:48 PM
chuck1177's Avatar
ok thanks
Old May 13, 2013 | 01:10 PM
chuck1177's Avatar
ok i re checked the voltage at pump harness and im only getting 3.5 volta at pump ! could this be a ecm problem again ? 04.5 polaris sportsman 700 efi ! how do i test the solid state relay ?
Old May 13, 2013 | 02:38 PM
chuck1177's Avatar
i just took it back to dealer and let put digital wrench on it ! will reply back with results
Old May 14, 2013 | 09:00 AM
chuck1177's Avatar
ok it was a faulty fuel pump ! i was getting the low voltage cause the pump would only come on to prime it and then shut off . i shouldve been checking it right as soon as i turned the key on
Old May 14, 2013 | 03:49 PM
Yes,then you could have caught the voltage drop. Dealers have replacement pumps now and you don't have to replace the whole fuel tank,but if you are planning to replace the pump yourself and save a little money,Airtex pumps at Autozone and Napa are what a lot of people on the forum have said that works.Airtex Master/Fuel Pump (E8198) | AutoZone.com
Aitch
Jul 21, 2015 09:40 PM
trouttracker
Jul 19, 2015 11:50 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
