grease fittings
Old May 18, 2013 | 08:20 PM
Doneuald's Avatar
Default grease fittings
Hi all, longtime lurker, second time poster!
OPT I have a question about grease fittings, My 02 sportsman is missing one on the front left lower control arm, not that it was there but there isn't even a hole. My question is how were they mounted just drill a hole and thread it or do I have to weld a bung on to put one on?
Thanks for your time.
Don
Great site, lots to read and absorb
Old May 18, 2013 | 09:47 PM
Your model came equipped with grease fittings (7080433) but if it's ever been replaced it's possible the superceded part number omits it. I've had several a-arm replacements that came in that went to the latest model,ones without the zerks and bushings were changed also! It's a threaded zerk fitting. I believe it's a 1/4-28 and available at any auto supply. I just tapped em out and installed the zerks I had in stock to match the other side that had one. Easiest thing is just take one out and match it up if you have to. http://www.cyclepartswarehouse.com/f...2002&fveh=5582
Old May 19, 2013 | 05:25 AM
Doneuald's Avatar
Thank you sir, just wondering if it was a mistake or I was just "not" seeing things, will drill and tap then grease
Thank you for the reply
Don
Old Oct 20, 2014 | 07:40 AM
H.M. Gould's Avatar
Where can I find a diagram showing the grease fittings on a 98 500 Sportsman?
Old Oct 20, 2014 | 08:53 AM
Owners manual shows the locations in the maintenance section. You might try here to see if you can download one.Polaris ATV, Snowmobiles, RANGER, Victory
Plus a good service manual has most zerk locations also.https://www.tradebit.com/usr/tradema...pairManual.jpg
Old Oct 20, 2014 | 12:33 PM
H.M. Gould's Avatar
Thank you sir, I will do that.
Herb
Old Oct 21, 2014 | 09:16 AM
TLC's Avatar
TLC
Must be a replacement one. My Sportsman has like 23 or more zerks and I think the new 500 have like 5 now.
Old Oct 22, 2014 | 03:16 PM
Big600twin's Avatar
My 2003 600 did not have grease zerks on the A-arms. When I had to replace one(nasty tree stump collision). The new a arm had a grease zerk.
Old Oct 28, 2014 | 12:09 AM
jimmypsp700's Avatar
2002 has many 2003 went 'zerkless' for the most part. A-arms changed between the years also and bushings used...
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
