400EX power problem please help
Old May 20, 2013 | 09:35 PM
Elijah445's Avatar
Exclamation 400EX power problem please help
I got a 2004 400ex 4 wheeler and there is no power to it no neutral light. The lights don't work it wont even try to turn over at all got a brand new battery on it. It was working great tell one day it just shut off after riding and never been turned on again its been about 7 months now and we can't find any thing please help.
Old May 21, 2013 | 12:27 AM
MarioWeldingInc's Avatar
did you check the fuse? what is the battery voltage?
Old May 25, 2013 | 11:40 AM
Neverdone's Avatar
bad ground wire maybe?
Old May 25, 2013 | 10:35 PM
Pstroke96's Avatar
Default Power solution?
Check under the front plastic there is a harness connector that went bad on my 01 400 the harness has a black a red and a black/white the red is the positive from the battery all the way to the key switch and the pin in the connector went bad on mine all of a sudden no warning I had no lights neutral light starter at all I followed it back found the bad spot jumped it with a wire and she lit and fired right up soldered in a new wire and has been fine rest of the day hope that helps
Sjrpp
Nov 15, 2019 09:59 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
