gear oil in a 200e?
Old May 29, 2013 | 10:18 AM
mudmike's Avatar
Question gear oil in a 200e?
Sup guys. I have a 200e I submarined 3-4 months ago. After towing it home and draining the carb and fuel tank I decided to see if it would fire before I changed the oil. Sure enough blown head gasket. Anyways I finally ordered parts a couple days ago and pulled the engine yesterday. I pulled the pull rope assembly and loosed the bolts to the cover that is under it (covers the workings of the starter?). The fluid that came out was greyish brown and pretty thick if not for the pungent smell I would have just figured I had water in my oil. But this stuff smelled just like gear oil (the stuff you put in the rear differential on your pickup). I was under the impression that the engine oil lubed everything on this engine. Is there suppose to be gear oil in there? Is this just an oil/water mix that has developed a smell over time? Did the PO put LUCAS in it? ( Hmm, it looks like gear oil, it's as thick as gear oil, and it smell just like gear oil I wander what LUCAS actually is?)
Old May 29, 2013 | 10:51 AM
TLC's Avatar
TLC
Here is a manual to look it up. http://campaigns.hondampe.com.au/Mot...84atc20001.pdf
Old May 29, 2013 | 11:23 AM
mudmike's Avatar
thanx just says oil which is what I thought. just wondering why it smelled like gear oil.
Old May 29, 2013 | 02:30 PM
TLC's Avatar
TLC
Not sure but my old Honda Big Red (250ES) 3 wheeler just used motor oil only.
Maybe the water changed the smell some how.
Old Jun 11, 2013 | 06:38 PM
mudmike's Avatar
Thanks tlc that's what I was thinking but just wanted to make sure.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
