'85 250sx
Old Jul 23, 2013 | 07:54 AM
rcgross55@gmail.com's Avatar
Default '85 250sx
I'm looking for a cdi box for a '85 250sx , seems nobody makes an aftermarket igniter for this scooter ,the old one has a hiccup an needs a sharp tap every now an then to get it firing......I've found cdi's on line that have the same plug , but they don,t work on this machine......any suggestion?....thanx...Bob
Old Jul 27, 2013 | 02:54 PM
hermie's Avatar
royal disrributing
your model is an 86 not an 85
part number A01-115617 $79.99 cdn
they are based in canada and they do ship to the U.S
you can also order their catalog online
hope this helps you out
Old Jul 28, 2013 | 08:10 AM
hermie's Avatar
i forgot to mention
use some automotive header tape and wrap the new cdi unit in it
( this will protect the cdi module from being cooked from the engine heat )
also switch your engine oil to SHELL ROTELLA T6 synthetic diesel engine oil
( it has 0 friction modifiers , lubricates better / better shifting / cooler running engine )
remember if the rotella can properly lubricate a high torque diesel engine , a small 4 stroke atv engine is a walk in the park for this oil
also start using 91 octane fuel / 87 octane fuel is bad for a air cooled engine runs too hot
Alans250sx
ATC 3-Wheelers
Nov 21, 2007 04:08 PM
haywoodjalikme
ATC 3-Wheelers
Apr 17, 2006 01:00 AM
HondaCrazy85
ATC 3-Wheelers
Oct 16, 2004 09:52 PM
BigRed1985
ATC 3-Wheelers
Jul 27, 2004 05:21 AM
HondaCrazy85
ATC 3-Wheelers
Jun 19, 2004 09:41 PM
