Rear shock adjustment
Old Aug 17, 1999 | 10:44 AM
talon400's Avatar
I have a '99 Scrambler and I want to set my shock up. At the bottom of the shock you have the PLASTIC ring that screws up and makes the shock tighter. I have tried to adjust this and have had no luck. I cant even get it to budge. Does anyone know of a easy way to get this done without marking up and pulling on the plastic ring? I know that the tool that comes with it is made for the adjustment but the darn thing wont work. Any suggestions would be greatly appreciated.
Thanks
Chuck PROUD owner of the '99 Scrambler
Old Aug 17, 1999 | 11:38 AM
mudmachine's Avatar
Talon,
Keep working with it. If you STILL can't get it to move, it might be cross-threaded.
I'd look for some type of lockscrew first though... My 97 doesn't have one... BUT, you never know!
If that doesn't work, either rent a spring compressor, or get a heavy buddy to sit on the rear of the machine(to compress the spring) then take some strong cable or heavy duty nylon tie downs and tie the coil spring down. Get your buddy off of it, and THEN try to move the plastic adjuster nut. (It should have VERY LITTLE PRESSURE ON IT NOW) If it STILL won't move, you have a problem.
Good Luck!!!
Old Aug 17, 1999 | 05:31 PM
01ds650's Avatar
On my '99 Scrambler 400 sometimes there is dirt on the threads etc. that make it hard to turn. I usually spray WD-40 or something on it and once I get it to move I'm OK.
just a thought...
c-ya,
Andrew Thomas
'99 Scrambler 400 (New & improved with RCR kit and more raisins than ever) & '99 Trailblazer for Baby Butt Cheeks...
Old Aug 18, 1999 | 08:47 AM
motorman's Avatar
take the weight off of the shock by jacking up the quad by the frame and it will turn much easier.
Old Aug 18, 1999 | 10:40 AM
talon400's Avatar
I fixed it guys thanks for all of your help.
Happy Trails to you!
CHuck
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
