Help!!!
Old Aug 8, 2013 | 08:51 PM
2003wolverine350's Avatar
Default Help!!!
should i buy a power kit intake for my quad or just a k&n air filter which would be bettter/easier?
Old Aug 10, 2013 | 01:12 AM
nukacola's Avatar
I don't know, but I can say that the foam gasket for K&N on my 95 Moto 4 350 is not quite thick enough and doesn't make a tight seal. I'm going to seal it up with windshield sealer gasket. The K&N lets in a lot of air and you might need to go up a size on your jet or raise your needle in the carb.
Old Aug 10, 2013 | 05:54 AM
2oooVVarrior_rider's Avatar
on my warrior I have the k & n and its fine but with stock air box lid it wont do much, I would recommend getting an outerwears filter cover or some kind of lid modification to allow more air to the filter. And with the K & N make sure to check it and make sure it stays clean. O almost forgot for the wolverine you can get the filter and outerwear for like 70-80 dollars.
Old Aug 10, 2013 | 08:03 AM
LT80's Avatar
LT80 Expert
Stick with a good foam filter unless you are running high rpm's for racing.
