2001 rubicon- Oil Pump vs. Clutch ??
Old Aug 18, 2013 | 11:33 AM
Inhoc131's Avatar
Default 2001 rubicon- Oil Pump vs. Clutch ??
I have a 2001 Rubicon that makes a grinding noise once warmed up. It sounds like it is coming from the Shift control motor area once the grinding starts it just makes the grinding consistent with the throttle and loses it ability to move under a load. The bike runs normal at cold start then begins its antics. Im not sure if this would be a oil pump issue or a clutch issue? I can tell you I'm only able to shift into 4th gear in ESP mode. Any thoughts?
Old Aug 19, 2013 | 08:27 PM
Inhoc131's Avatar
Any Help or Idea's?
Old Aug 22, 2013 | 11:01 AM
TLC's Avatar
TLC
If I remember right ,when the complicated hydrostatic Rubicon tranny came out , I read in Dirtwheels magazine that its down side is Honda made the tranny unserviceable.
If the tranny quit it had to be changed as a complete unit for like $1,300-$1600.
Other sites have mentioned it. 2001 Rubicon transmission issue
and
http://www.hondaforeman.com/128-fore...smissions.html
Old Aug 31, 2013 | 11:36 PM
JRM's Avatar
JRM
same issue is the video in your other post? Make sure you have the flat washer on the oil filter in the correct spot, I put mine in backwards a decade ago and It caused issues, but nothing as drastic as you describe. there used to be a hondamechanic on these forums way back in the day- id do a search to see if he is still a member
ghost civic
Jan 15, 2020 07:43 AM
Hunter100us
Oct 7, 2015 11:46 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
maxjung
Jul 14, 2015 03:10 AM
Mikea1978
Jul 4, 2015 12:37 PM
