Sportsman 500 Trouble
Old Sep 10, 2013 | 11:17 PM
Sykwidit's Avatar
Default Sportsman 500 Trouble
I believe it is a 1996. Couldn't find vin but seen model number. Its a 500. I have a starting issue. I bought it for 700 bucks. Looks like it was barely even ridden. It has a start issue.
I clean out flywheel housing had water and grease inside. Bendix gear was bad also it was missing the bushing. You could hold start button and pull the cord "keeping pressure" on it. It would crank. If you gave it any gas it would stall.
Anyone have any ideas? Starter does sound like it is free spinning now. But doesn't engage. But a bad starter would make the tension needed on the pull cord would it?.
Like to get this running. Oil clean, piston looked good. Seems they had a issue with override and left it. So where do I start now?
Old Sep 11, 2013 | 04:15 AM
Check this place out for starters and bendix if you need one or the other or both. DB Electrical - Sportsman Then sounds like you may need a carb kit.
Old Sep 11, 2013 | 06:22 AM
Sykwidit's Avatar
I replaced the bendix, but the starter washer has me puzzled it was missing.
Also why would you need to put tension on the pull cord to get the bendix to engage. Hate to throw it on cl or have some local charge me a arm and it be a over looked error issue. Any help would be greatful thanks for responding all week not one other site has help any
Old Sep 11, 2013 | 07:02 AM
If you're talking about the washer behind the bendix,check the old one to see if it's still stuck on. If it's not a local hardware store may be able to help you on this thin washer. If you have to pull the recoil to move the flywheel a bit to get the bendix to engage is either because of the missing washer or the bendix(even though new) is sent dry and may need a little grease around it to get it to engage the flywheel properly,then kick back in out of the way. Item #13 on the washer. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Sep 11, 2013 | 07:03 AM
Sykwidit's Avatar
Thanks am going to take it apart and check. Will report back.
Old Sep 11, 2013 | 07:07 AM
See if this helps.
Old Sep 12, 2013 | 04:44 PM
Sykwidit's Avatar
I check polaris oem part numbers. Seen the starter bushing. Doesn't match the washer/bushing in videos. ???
Old Sep 13, 2013 | 01:14 AM
If you're talking about the starter bushing and not the washer behind the bendix,there are two bushings.One in the recoil housing and one in the engine case. If either are galled or damaged they can cause problems with the bendix operating properly. #9 in the parts breakdown,one in the engine is the same#.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Sep 13, 2013 | 01:21 AM
Sykwidit's Avatar
So number 9 is in just flywheel housing? I figured cooper washer behide bendix and starter bushing in front of bendix. Thanks for help. Really want to try out this awd and 500cc. Honda Rancher 400 was a major let down.
Old Sep 13, 2013 | 01:31 AM
Sykwidit's Avatar
Also I read you post a out unplugging a black wire to disengage override system? I can't seem to find out the yr am guessing its a 96. Circuit board is in front of atv under headlight.
