Engine Seized (Hey OPT!) Everything that has happened
Hi guys and OPT,
I was getting ready to take the engine out and decided why not crank it up and see if i can prime the oil. The engine seized up. I started looking at my manual, the oil feed and exhaust was mixed up. This is the entire reason the engine was not running smoothly. So i called the seller up and cancenlled the refund because i didn't want to lie to him and take the refund.
I squirted some penetrating fluid in the spark plug gap and am going to let it sit overnight. Hopefully i can get the piston moving up and down. If so, the oil will actually lubricate the engine. If not, i will have to do some interior work.
History:
Bought a fourwheeler that didn't work for 400$
Got the engine running
Made a loud noise
Piston had been sheared and broken off
Bought a used engine off ebay for 675$
Oil wouldn't get in the engine (Now i know why)
Engine is seized
Piston has lubrication in top that will, hopefully, get into the sides.
What should i do to help get the piston Un-Seized?
Oh, and OPT,
Thanks alot. I'm sure you know everything about my fourwheeler and the history as of now. LOL
History:
Made a loud noise
Engine is seized
Oh, and OPT,
All depends on the extent of the damage. If a pistons seizes and locks up,tear it down to inspect it. Expect to at least have a new top end and possibly more if the rod or crank bearing are damaged from lack of oil. Read your manual on the engine section to understand this engine better!!
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
