04 Bruin 350 2WD - Remove Rear end to replace shaft boot
This site is always helpful. I have an 04 Bruin 350 2WD that needs the drive shaft boot replaced. I have ordered the boot and the oil seals for the transmission side and rear end side. I had to do this back in 2007, but for the life of me cannot remember exactly how to remove the rear end (ie drive shaft, u-joint, etc..). I know if I remove the bolts on the rear main arm and remove the brake lines, the rear-end should slide right away from the drive shaft. But since I am going to replace the oil seals on both ends, can someone give me a bit of guidance about the rest??
Rooky
10
Jun 23, 2015 09:35 PM
