500 sportsman/air intake
Old Aug 20, 1999 | 12:44 PM
Harold's Avatar
One of my friends rides a 500, after looking his quad over it would appear to me that Polaris should increase the size of the carb.snorkel, seems to be pretty small for a 500cc engine.
Old Aug 25, 1999 | 02:44 PM
Jack's Avatar
Glad you noticed also. I think it's the size because of the small 36mm carb on the SP500. I've always thought that a bigger carb would do wonders for this motor.
www.godigital-design.com/schultzmotorsports
Old Aug 25, 1999 | 06:40 PM
Willie B's Avatar
I agree, they should set the motor up the same as a Scrambler 500. 40mm carb and new cam. Just a thought? Look out Griz!
WillieB - '99 Scrambler 500
Old Aug 25, 1999 | 07:55 PM
Sburdman's Avatar
Jack,
You must be slipping, Polaris only puts a 34mm on the 500 Sportsman. Same size they put on the 400. At least we know there is some free power there.
Scott.
Old Aug 25, 1999 | 10:03 PM
Kagey's Avatar
Anyone ever try the 40mm on the sportsman or magnum 500? Sounds interesting but I don,t really want to be the one to test it.
Kevin Gowdy AKA-Kagey1999 Polaris Magnum 500
Old Aug 26, 1999 | 11:37 AM
myscrambler's Avatar
I had a 39mm carb with high air flow intake that went into the airbox with a K&N on it on my 97 Sportsman 500. It did do wonders for the Sportsman. I could easily hang with anybody on the trails. Very very fast. I got the kit from four stroke tech in PA. I had alot of extra weight due to aftermaket goodies plus I had the heaviest tires made the vampires all around and it still would blow away a 98 scrambler with a pipe a clutch on top end in a straight race. Real close race at the start and soon it would just take off. I put it up on the road twice to see if I could hit top speed but both times I had the speedometer buried and it still had alot left. I know I went at least 10 mph faster once the needle buried and then I would run out of room so I never did reach top speed. Very big increase in performance but a bitch to install.
Later,
Steve
Old Aug 26, 1999 | 12:21 PM
Harold's Avatar
Does four stroke tech. have a web site?
Old Aug 26, 1999 | 12:47 PM
Jack's Avatar
Scott, you are right I'm slipping. I guess I can't get over the shock that they would put a CV34 Mikuni on a 500cc motor. I'd love to find something that can add a little better top end performance. You can really feel that it hits a wall at about 35 mph. It seems like it just wants more fuel. I've though that a 38mm or thereabouts may be about the best combination. I do know of one with a 42mm that 4ST did that doesn't run real well off the line.
I really don't want to get too carried away with modifying the engine, but a carb and possibly a cam are not too severe. The damn thing need to breathe a little.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
