Sportsman 700 ignition wire
Old Oct 21, 2013 | 02:16 PM
1shotbob's Avatar
Default Sportsman 700 ignition wire
2002 Sportsman 700
I was changing the plugs when one of the wires broke off and left a tip on the plug. Research says I need this wire: 4010124-66 but everyone tells me they are no longer made.
So what do I use instead? What is the replacement part?
bob
p.s. it’s the left side wire if that matters.
Old Oct 21, 2013 | 02:34 PM
You can always get a length of 7mm plug wire and match the plug cap up that will work at a lot of auto supply houses or motorcycle shops. Just my on this though,if you still have the Ducati based ignition, search this or any other forum or just Google 700 Polaris ignition problems and you'll find a lot of ignition failures on the 2002 to early 2004 700s. Here's the pdf replacement kit instructions that you might keep in mind as the ignition can go out at any time. Kit isn't cheap,around $500.http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Old Oct 21, 2013 | 09:36 PM
1shotbob's Avatar
Thanks OPT. They guy I bought it from said the upgrade has been done already.
I took the quad swimming over th eweekend and I’m just trying to get it back to normal.
I’ll go to the parts store tomorrow for an ignition wire.
Does the wire just pull off on the coil end?
bob
Old Oct 22, 2013 | 06:41 AM
This I can't remember off hand(may be sealed),but you can get a plug wire splicing kit at a lot of auto/cycle stores.NGK Performance Products - Splicers
Old Oct 22, 2013 | 09:05 PM
1shotbob's Avatar
Thank you.
bob
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
tweeder
Jul 5, 2015 01:57 PM
ranvette
Jul 4, 2015 06:13 PM
D-Hagz
Jul 4, 2015 02:19 AM
