reverse button override
Old Oct 26, 2013 | 10:07 PM
lowflyer's Avatar
Default reverse button override
I have an `02 Sportsman 500 and am setting it up to plow. I read the applicable thread to modding the reverse button and while looking at the wiring diagram it looks like I could splice the purple wire to the gray/white and achieve the mod there.?
Old Oct 27, 2013 | 09:15 AM
Schematic shows 3 wires to the overide switch,purple(reverse),grey/white (awd power) plus there's a grey/red in released position that contacts the purple. Try this jump on the grey/white and purple and see if it works.
Old Oct 29, 2013 | 11:03 AM
lowflyer's Avatar
I appreciate the input OPT. I think I found the wires in a harness by the radiator cap. When I get back to it and make the splice I will surely post results. It`s cold and nasty here and have lots of chores besides this.
Old Oct 29, 2013 | 01:35 PM
If you're talking about the module up from the radiator,that's the regulator rectifier.The reverse limiter is built into the speedo and wiring goes from the speedo harness to the left control switch. You'd either have to tap into the switch wiring or at the speedo. And I can't say whether it would affect the speedo if you did it there or not. Item #35. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 29, 2013 | 01:52 PM
lowflyer's Avatar
I`m referring to wires in split loom coming from handlebar switch. The split loom is rearward of the radiator cap and the wire colors are consistant with the diagram. Admittadly I`m concerned that these are the right wires. The speedo is screwy anyway so don`t care about that much.
Old Oct 29, 2013 | 01:57 PM
Give it a try then..
Old Nov 6, 2013 | 12:30 PM
lowflyer's Avatar
I cut the purple and gray white wires in the loom behind the radiator. Used my trusty power probe and deduced the correct end of the gray/white to work with. Jumped the gray/white to the hot side of the purple wire and have 4wd in reverse without pushing the yellow button. The bad side to this is the reverse indicator light comes on in forward gear. So I`ll be tapping off of a red/white wire as the posted tip states. You live and learn. Nothing damaged and I`m on to to not having to push the yellow button. Don`t know why they did it to begin with. If I don`t want 4wd in reverse now I`ll just turn off the awd switch.
Old Nov 6, 2013 | 01:02 PM
Try this method instead. How one guy wired his up.
Trace wires from the override button (gray/white & gray/orange) Cut the gray/orange and tape up both ends. Cut the gray/white and tape up the end which goes to the override button. Connect the other end of the gray/white to the red/white (ignition supplied 12v) You may or may not have the reverse indicator show up on the speedo though.
Old Nov 12, 2013 | 01:20 AM
lowflyer's Avatar
[quote=old polaris tech;3219956]Try this method instead. How one guy wired his up.
Trace wires from the override button (gray/white & gray/orange) Cut the gray/orange and tape up both ends. Cut the gray/white and tape up the end which goes to the override button. Connect the other end of the gray/white to the red/white (ignition supplied 12v) You may or may not have the reverse indicator show up on the speedo though.[/quo
Got er done. Reverse indicator works as before. Now I have awd in reverse whithout having to push the stupid yellow button.
Old Nov 13, 2013 | 12:05 AM
Glad it worked out for you and the reverse indicator works.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
