06 honda trx500 fe electric shift problems
Hi I am new to the forum and have a 2006 honda trx500 fe es which stops shifting when riding, I have brought up the code but cannot find a solution for the problem, is there anyone who can give me an idea where to start?
Yes angle sensor is most of the problem on these ES models. But before you change out like said check wiring and connection to sensor,also may sure shift button is sending the signal to angle sensor to shift...If not getting signal to shift get back here..Good Luck
