04 polaris 500 ho 4x4 atp
Old Oct 29, 2013 | 02:45 PM
RAINS's Avatar
Default 04 polaris 500 ho 4x4 atp
the cluster comes on when you first start up then in about 5 sec. it goes off. it only has 956 miles always been inside never has got wet or anything
Old Oct 29, 2013 | 03:54 PM
You have two thermal circuit breakers in plastic pouches,one is the main 20 amp circuit breaker and a 10 amp breaker is under the front panel for the fan. The 20 amp main circuit breaker should be along the harness up from the starter solenoid if I remember correctly on the Atp.If this breaker has corroded terminals it can trip the breaker and cause the speedo to blank out. Slice open this pouch and see if it need replacing. You can get it at most auto stores.Duralast/20 Amp metal circuit breaker (CBR210) | Circuit Breaker | AutoZone.com
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
