Rear Brake Master Cylinder 99 Sportsman 500
This system is sometimes hard to bleed,a Mity Vac or similar brake bleeder might help,but if you're sure the master cylinder is bad or if the seals are leaking it has to be replaced. Not cheap,so make sure you eliminate any air in the system or caliper problem.Item#18. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
toonces
Oct 16, 2019 12:11 PM
