kawasaki klt200 fuel pump ?
Old Nov 6, 2013 | 01:41 PM
theddaug's Avatar
Default kawasaki klt200 fuel pump ?
Hi guys
I have a ? about my 200 klt I am having a problem with my fuel pump
it appears to not be working it looks to be a diaphragm pump does anyone know of a replacement that will work for me that would be fairly easy to find
or if a kit to rebuild would be easy to find or can it be switched out with something like a small electric pump or somthing
Thanks theddaug
Old Nov 6, 2013 | 02:31 PM
MonkOFox's Avatar
http://www.ebay.com/itm/KAWASAKI-KLT200-KLT-200-1981-1983-FUEL-PUMP-KEIHIN-OEM-49040-1002-ATV-ATC-PETRO-/400562408913?pt=Motors_ATV_Parts_Accessories&hash=item5d43614dd1&vxp=mtr is up for buying. Also If you look at the specs, I think it says the fuel pump should pump up to 1.2 - 2.2 psi to the carb. If you can rig up a comparable pump to supply fuel to the carb, should be fine.
If all else fails you could always cut the plastics covering the area where tanks are on every other bike. Make-shift install a different tank and throw a fuel hose from its petcock to the carb, eliminating the necessity of a pump all together.
Are you sure it's not an electrical problem or that the pump just doesn't need some fierce cleaning?
Old Nov 6, 2013 | 02:41 PM
theddaug's Avatar
I have a clear fuel filter on it and not getting fuel to it I can siphon and can pull to it so think it is pump is there a way to check pump
Old Nov 6, 2013 | 03:16 PM
MonkOFox's Avatar
Can turn the key on and check the voltage at the pump see if it's hot at all. Did it recently stop working, or did you buy it like that? If there isn't, look for damaged wire, not sure if there is any kind of fuse or not but check that if there is.
Old Nov 6, 2013 | 03:28 PM
theddaug's Avatar
Hi monkofox
It is not electric pump it is original diaphragm pump and does not pump no more took line off at carb and turned over got nothing so was tring to find out what will work for sub any ideas would be great suggestion of inexpensive electic
not sure of psi seen psi in this post but saw one earlier that said like 3-6psi
any ideas
thanks theddaug
Old Nov 6, 2013 | 03:42 PM
MonkOFox's Avatar
KLT200/250 Service Data
That is the service data for the KLT. Sound like the bladder is damaged or one of the valves. You may be able to find replacement components on Ebay.
Old Nov 6, 2013 | 03:45 PM
MonkOFox's Avatar
If nothing else, create a thread on 3wheelerworld.com, in the ATV Classifieds forum and see if anyone has any parts for sale.
Old Nov 6, 2013 | 04:01 PM
theddaug's Avatar
Any idea of electric that would work
I found a 2.5 to 4.5 psi would that work
theddaug
Old Nov 7, 2013 | 01:00 PM
MonkOFox's Avatar
The specs say anywhere from 1-6 psi I believe. So it fits the range, just have start at 2.5 and see if it supplies the needed fuel amount over 30 seconds time. I don't know how to rig it up to work with the ignition though.
Old Nov 7, 2013 | 09:02 PM
theddaug's Avatar
Thanks Monkofox
I will play with this and let you know what I do
I am gonna try to find a diaphragm pump locally
I have a small shop that has been pretty good to me
Thanks thddaug
