DS 650 problems starting
Old Nov 10, 2013 | 06:21 PM
kfields_5's Avatar
Default DS 650 problems starting
Ok guys my 2000 650 is having problem starting. Put in a new spray clutch and cleaned the carb all up nice. Now it won't start. i just keeps turning over. I checked the plugs and they are getting stark. Im going to get new plugs tomorrow and see if that might help. I wanna do a compression test and see how that goes. Can some one walk me through how to do a compression test? I also wanna check the timing. Can someone please walk me through how to check the timing?
Old Nov 13, 2013 | 08:59 PM
MRDS650's Avatar
Canadian and Proud of it !!!
You are experiencing a very common problem. You have a couple of bent Shift forks in the tranny. I have done the repair on both of my DS650's. It is a pretty involved repair but not really hard. There is a great set of instructions on here done by Hightower with pics and everything. If you are able you can do it yourself. When you get it apart (splitting the cases) it best to send the tranny gears to Eric at OMW to have him back cut the gears. It makes the tranny shift like butter and you will never miss a shift again.
Old Nov 13, 2013 | 09:07 PM
kfields_5's Avatar
do you have any idea how much that is for eric to do that. man you saved my life.
Old Nov 13, 2013 | 09:14 PM
kfields_5's Avatar
will the shift fork the only thing i will need or is there other parts too. and will it work fine if i don't send it the eric
Old Nov 13, 2013 | 09:31 PM
kfields_5's Avatar
what does the shift fork do
Old Feb 18, 2014 | 05:43 AM
DSATVrider's Avatar
Did you ever solve your problem?
I seem to be having the same thing happening to me. I was also going to chech compression and timing.
If you figured anything out please let me know.
Thanks!
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
