Lift Kits - Will a 2010 lift kit fit a 2012?
Old Nov 23, 2013 | 02:41 PM
WilliamBos's Avatar
Default Lift Kits - Will a 2010 lift kit fit a 2012?
I have my eye on this lift kit...
Lift Kit Polaris Sportsman ATV 2"
But he says that the 2010 kit will not work on my 2012 400HO. What has changed??
Royal wants $150 for this exact same kit.
Old Nov 23, 2013 | 06:01 PM
2010 400 was based on the compact import Hawkeye type frame with a different transmission and different struts. Your model is the full size one and shares the same components including strut cartridge as the 2010 Sportsman 500. He may have been confused and thought you had the 2010 model 400 which is completely different on the front struts. Seems like this kit should work.2010 Sportsman 400. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
2012 Sportsman 400.http://www.cyclepartswarehouse.com/f...012&fveh=51400
Old Nov 23, 2013 | 06:03 PM
WilliamBos's Avatar
2010 400 was based on the compact import Hawkeye type frame with a different transmission and different struts. Your model is the full size one and shares the same components including strut cartridge as the 2010 Sportsman 500. He may have been confused and thought you had the 2010 model 400 which is completely different on the front struts. Seems like this kit should work. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Thanks a ton OPT!! So, the fullsize struts are identical then, eh??
Old Nov 23, 2013 | 06:05 PM
Your 2012 400 uses the same strut and cartridge as the 2010 Sportsman 500 that the kit lists will fit.
speedbuff
13
Nov 11, 2020 10:16 AM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
WilliamBos
Sep 22, 2015 04:07 PM
greg74
Sep 10, 2015 07:58 AM
