82 250r gearing help
Old Nov 26, 2013 | 04:58 PM
Alexx Abrunzo's Avatar
Default 82 250r gearing help
im looking to make my 250r more trail friendly/ less clutching/ feathering on trails. ( not mudding it or drowning it) , just trail traveling to dirt pits . i dont need high top speed i mostly use 2nd and 3rd sometimes 4th depending on momentum for the huge dirt hills. also the daughter has been bugging me to take her on a little trail ride like i use to with my 200 atc and 225 Yamaha , but im a little worried to do that with this machine cuz i have to keep the revs high traviling over rocky hills, i LOVE the 250R !, any help would be great thank yu
i live in northern Canada, ontario
Old Nov 26, 2013 | 06:20 PM
Scooter86's Avatar
Knows Old ATV Questions!
The quickest/cheapest way to lower the gearing is to go down one tooth on the front sprocket. This usually makes a pretty noticeable change and does result in a lower top speed(usually.) Beware going to something really small like a 10T though, as the chain will wear faster having to make that tight turn on a little sprocket. You can also add teeth to the rear for the same effect. +3T rear is approximately the same as -1T front. You will lose clearance this way. If you run a swingarm skid / chain guard that is already tight a bigger rear may need some engineering or may just not work.
Being a 2 stroke, a different pipe may do wonders moving the powerband down the rpm range as well.
Old Nov 27, 2013 | 07:10 AM
budedm's Avatar
You won't ever get away from the constant shifting with the R because it's a 2 stroke and the power band is very narrow. You can change sprockets like Scooter said but that will just move your shift points to a different RPM. It won't change how often you need to shift. The R was not made to do what you want. It is a lean mean racing machine. You need a newer 4 stroke that is fully automatic and has some low end grunt if you want to lolly dag through trails with your daughter.
Old Nov 27, 2013 | 11:14 PM
thanks ill go down 1 on the front sprocket n up a few on the rear n look for a pipe that'll move the power band down, if u have any ideas on who makes a good pipe for this lemme know , and no id rather stay far away from 4 strokes as possible every single one iv owned new or old they all let me down n a 2 stroke has never let me down yet , ill just end up buy her a little 50-100cc quad
also the bike has a honda line kit 300cc
Old Nov 28, 2013 | 12:58 AM
Scooter86's Avatar
Check your PM's. Also, I would just do the front sprocket and try that before changing out the rear as well. One tooth can make a pretty big difference. I have had a couple 2 strokes that were happy enough to putt around on, but you do need to run them every so often to keep them clean. Personally, I think getting your kid on their own age/size appropriate machine will be that much more fun for the both of you.
Old Nov 28, 2013 | 01:53 AM
this bike seems very happy , always a one kick start,ill defiantly run her clean, i agree i do need to get her own little machine with a speed limiter till she gets the hang of it, i appreciate the advice , have a great night
Old Nov 29, 2013 | 07:45 AM
LT80's Avatar
LT80 Expert
I ran a 12/40 when I went to woods gearing.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
