4 wheel drive
Old Dec 11, 2013 | 11:28 AM
dakotadave's Avatar
Default 4 wheel drive
i have a 1993 polaris 250 2 cycle 4x4 when i put it in 4 wheel drive the thing pulls to the right bad any help
thanks
Old Dec 11, 2013 | 12:53 PM
lowflyer's Avatar
thanks
Take it out of 4wd and back up. The hub should release. Mine does this once in a while.
Old Dec 11, 2013 | 01:45 PM
They all occasionally lock up especially in cold weather,but if you haven't changed fluid in a while I'd do this first.If this doesn't help on the one side lock up,you could have a magnetized armature plate that needs to be replaced.They can lock up whether you're in awd or not. Just my two cents,I'd replace both armature plates as usually the other side will eventually do the same thing.I had to change out quite a few of these. Item#8.
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
