1997 warrioe please help.
I got a 1997 warrior. The rear caliper fell off. U know the top pin that hold to that medal piece that comes out by the rotor. The pin worked itself out. Di I have to replace that?? I am not sure. The problem caused it that my rotor got bent, and my caliper was going back and forth. Try to help me please.
Tooey.
My son has a 97 Warrior, but I work on it all the time. The pin that you said fell out, are you talking about the top bolt? If so you have to replace it. If your rotor is bent you should replace it. How are your bearings? I've put 2 sets of axle bearings in, 2 sets of wheel bearings in, 1 set of swing arm bearing in. Also put on sprockets, chain, alot of brakes. Let me know how you make out. How far is cadiz from Eastliverpool? I'm 15 mins from E.L.
lgardner61980
Sep 20, 2015 01:32 PM
