High beam problems
Old Dec 15, 2013 | 12:59 PM
megacab07's Avatar
Default High beam problems
I have a 2002 Sportsman 500 HO and the high beam light doesn't work. I replaced the switch and the bulb and still nothing. The low beams work fine. Any suggestions?
Old Dec 15, 2013 | 04:44 PM
Check the high beam connector plus follow the Yellow and Brown down under the headlight pod to see if you have a short or a faulty ground. This is a bad area as these wires have to bend down from the connector.
Old Dec 15, 2013 | 08:15 PM
megacab07's Avatar
Default high beam problems
I will give those areas a look. Thanks
Old Dec 18, 2013 | 11:22 AM
megacab07's Avatar
Found the problem. It was under the headlight pod-lead wire was broken on one of the loops. Thanks again Old Polaris Tech!
skinnyr6
Aug 25, 2023 02:18 AM
honda71
Jul 12, 2015 05:56 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
honda71
Jul 8, 2015 02:13 AM
MNatv89
Jul 7, 2015 11:36 AM
