efi stator hater
Old Dec 21, 2013 | 10:10 PM
early454's Avatar
Default efi stator hater
when I plow with my 06 500 efi I cant use my heated grips.if when I trail ride they work fine,but at low speeds they don't.if my headlights are on and I try to use them the check engine light comes on.they make plowing an awful lot better when they work!i see some stators on ebay that say they put out more voltage at idle.this must be a common problem with efi models.has anybody had any success with changing theirs?
Old Dec 22, 2013 | 03:22 AM
Check first that you're charging 14 to 14.5 volts back to the battery from the pdm. Plus if the battery is fairly old you might have it load tested. Could be too much current/amperage draw as you mentioned or it could be because of a low output pdm module or a weak cell in the battery.
Old Dec 22, 2013 | 10:31 AM
early454's Avatar
i tried the battery .I got a nice gel battery from adventure powersports with higher amps than the factory battery.i t has noticeable faster cranking speed when starting but didn't help problem.i needed a new one anyway and I liked the battery so much I bought another one 4 my girls quad.ill check the charging voltage again.it has done it since it was new.i don't have this issue with carb. models.it seems like the efi uses 2 much juice at idle with the fuel pump,injector,etc.
Old Dec 22, 2013 | 11:14 AM
It is kinda of a catch 22 on the direct current(dc/cdi) efi machines as they do use the battery for ignition which can take less voltage(low as 7 volts) for starting versus the old magneto triggered ignitions on the carb models,but they can have problems with load issues with multiple auxiliary equipment attached,that is if you rule out any charging issues supplying the battery.
Old Dec 22, 2013 | 08:17 PM
early454's Avatar
I checked the voltage again.warmed up at idle it is14.52,i turn on the headlights,13.32,i turn on the grips it drops down to 12.23.i believe rpm was 1385-1400.i see a company thet makes a stator for 110 bucks.they claim voltage at idle is better.if it truly is I think its worth it.i would like 2 hear it worked out for someone else 2 take the chance
Old Dec 22, 2013 | 10:30 PM
Yooper265's Avatar
Here in the U. P. I have two friends that had the same problem , I made them harnesses with Anderson plugs { heavy duty battery plugs } and they put a second battery on the back rack , one uses a large industrial gel cell battery the other uses a U1 battery from his riding lawnmower , they take the battery in at night and top if off with a trickle charger , both love it , lots of power and no lights dimming , etc . A lot cheaper and easier than trying a different stator that probably won't make a difference .
Old Dec 23, 2013 | 09:07 PM
early454's Avatar
so u just siamesed another battery 2 your existing battery with cables like a plow truck setup and that made it work?or was the add on battery much larger than an atv battery?
Old Dec 24, 2013 | 12:03 AM
Yooper265's Avatar
Yes , they're connected in parallel . The wires for the plug are connected to the battery terminals .
Old Dec 24, 2013 | 12:04 AM
Yooper265's Avatar
The extra battery is 3-4 times larger than the atv battery .
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
